Supid external HD
27 Sep 2004
Wasn't sure where to post this!
I picked up a new external HD today from a high street retailer because I required some quick portable storage for something. It's a Seagate slim drive, the retailer said it was non-refundable unless faulty - not a problem I assumed because after all, it's just a plug and play external HD - wrong....this thing requires software every time I want to use it on a machine!
I can't plug it into a mac and drop files whenever I feel like it! You need to install a dashboard which is 90meg and then restart the system...what good is that for work?!
£50 down the drain as far as I'm concerned unless there's a way to break this or make it editable without software?
It should work as drag and drop like any other external HDD, the software is for Backup and Cloud services, everyone I have used has worked perfect on a mac without any additional software.
