SUSE networking question - Still not working 100%
Commissario
16 Oct 2002
In the radio shack
OK, I've got SCO Linux installed and running and indeed as it's based on UnitedLinux it does seem very SUSE like.
I can ping that PC on the LAN but what I can't do, and what I need to do is to be able to access the internet from that box via my ISDN router.
During installation I gave it a static IP and a gateway. I can ping the gateway from that box but can't access the internet at all as I'd expect to be able to.
Can anyone give me a nudge in the right direction?
Thanks.
K.
I can answer this myself now - No DNS server configured. That didn't help :D
K.
Hmm, this has gone a bit pear-shaped.
Yesterday it was working OK because I was able to browse the internet and download the SETI client with no problem. After I'd got all the SETI stuff installed and a startup script configured I rebooted to ensure that it started correctly and when I tried to access the internet today I'm getting what appears to be the same problem.
My /etc/resolv.conf file reads
Code:
nameserver 192.168.0.211
domain local
I can ping other PC's on the LAN but if I try a ping to the outside world whether I use name or IP I get:
connect: Network is unreachable
I'm not running a full domain, my network is basically a workgroup. I can telnet to the IP of the linux box and log in with no problems at all.
Not sure what else I should be looking at...
K.
What does "route" show?
(Just type route as root in a terminal)
Shak
Code:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
.               *               255.255.255.0   U     0      0        0 eth0
K.
Right, solution to the problem coming up:
/sbin/route add -net default gw $GTWAY netmask 0.0.0.0 metric 1
Replace $GTWAY with your default gateway.
And there you have a working route, what seems to have happened is that the gateway isnt set up correctly :)
Shak
looks as if you not got a default gateway configured, carn`t remeber how to do it from the command line now, carn`t find me note's sorry. Try something like
route default gw ip eth0
may be eth0 then ip
ip=ip of gate way machine/router
deano
edit shak beat me to it...lol
Bingo - That has worked perfectly, thanks Mr. Shak sah.
/me goes off to look up the route command to see what I've done and why!
Will that be saved now, I assume I'll not have to do it again?
K.
You may want to add it to the startup script, so that it is run every time.
Shak
