Suspected flat battery
22 Oct 2005
Moving...
My 2012 Ford Focus didn't start yesterday. I got a jump start to get it going, then drove for 20 mins, went for a walk, then drove home without issue.
This morning it didn't start again.
Would I be right in saying that the fact that after the jump start it managed to start again under its own steam, but couldn't do the same the next day, hints more at a duff battery than an alternator issue?
Normally I'd just take it to my local garage to get it looked at, but I'm in France at the minute so 1) I don't have a trusty garage to rely on, and 2) my French isn't great, so if they could diagnose I likely wouldn't understand them :o
Battery is at least 4 years old (I've not changed it since I've owned it), it's a Ford battery so could even be original. In case it matters, it's a 1.0l ecoboost.
20 mins driving around will hardly have charged the battery at all, if its a ford one it's most probably the original and well expected to fail at 9 years old.
I'd get a new one, in the interim you could give the current one a good charge and it might last a while longer but will probably fail in the cold weather of the winter so i'd get it changed if you can.
I had to replace my Focus 1.6 Ecoboost battery in May, very similar circumstances as yours. Seems to be the average lifespan of most batteries. I went to Halfords and asked them to fit it too which they did with minimum fuss. Took about 45 minutes all in as the air box needed shifting to get the battery in but a mechanic or dealer would easily be £40+, maybe even closer to £100 for an hours work.
what driving had you done on the days preceeding the failure ? snce wouldn't expect failure to come out of the blue,
unless it was cold/med-hot or, had been driving few miles, over previous days.
norauto, the better brother, of halfords, in france, would probably change it; DIY'ing might be out if, as mischief suggested, you need to get more than a few tools.
So you have not charged it with a charger ? you need to try that because 20 minute drive wont be enough. It needs a long charge like overnight
A common symptom of a failing battery is things like the radio cutting out after only a few minutes if the ignition being off and if the stop/start stops working as well. That’s what also happened on my Focus.
OP is in France. Granted that he might still be able to get hold of a charger, but, as someone else said, with autumn around the corner I'd just replace it.
2 days prior it did ~500 miles to get to France. Then the day before it did a couple of 10-15 min journeys. It's not missed a beat before and there were no obvious signs that something was wrong prior. I'm 95% sure I didn't leave any lights on or anything silly to cause the battery to run flat in the first place.
I don't have a charger so can't try an overnight charge.
As misschief has said, it looks like the air intake and other gubbins have to be removes in order to replace the battery, so not something I feel comfortable doing myself.
The stop/start functionality has never worked. I wasn't sure if it was an option that wasn't selected by the original owner, but I never cared about it so didn't investigate further.
(parents don't have a battery charger they have aa homestart - maybe many do, but, agree, if you do the minimum of diy you have a charger)
If it has stop/start, disable that potential battery drain, do AGM (stop/start) batteries fail much more suddenly than lead acid, but that's a bit more expensive to have to replace abroad
My Smart Fortwo has stop/start but there’s a button to press that disables it every time I start the car, the doors also have to be locked too.
Have never liked it due to the extra stress on the battery.
When the battery failed on my 2010 Avensis about 3 years ago there were no signs before hand, just one day it wouldn't start, tested the voltage and it was really low. Tried a recharge but after a couple of days the same so just replaced it, modern ones do just seem to die without warning.
Stop/Start not working is normally an early indicator of a dying battery.
Do you have a multimeter handy. Could easily check how flat it is by testing the voltage.
Unloaded voltage isn't always a good indicator. Obviously if it's reading 3v or something, its scrap!
Given the description given by OP, I'd just pick up a new battery locally
Get it replaced
try and go for one that has a 5 year warranty like a Bosch
Everyone i thought, and jump leads, and a map incase, and i carry everything i need to change a tyre fast including a good jack, and i have a tyre inflator pump
No battery charger here. No jump leads either although that’s only a recent thing, I used to carry them. Map? On my phone on part of the car. No point in carrying a Jack, my car doesn’t come with a spare!
