Thing is Centre mavity do a hell of a lot more than just tracking via a Hunter Align. Depending on how adjustable your suspension setup it's a full day getting the car setup with corner weighting, diagonal weighting, multiple trial runs adjusting the bump/rebound settings etc and it's just your car being worked on, no-one else there.
If your car had OEM suspension with very little adjustment (a Mondeo for example) then yes CG are massively overkill and you'd be daft to spend that sort of money but for a car with fully adjustable suspension they are quite rightly regarded as one of the best in the UK.
Plus you're paying for Chris's knowledge too. A "kiwk-fit" align will be to a setting provided by the manufacturer of your car but these will be generic. With Chris you tell him how you want your car to feel (more turn in, less slip, more stability straight, more stability corner etc) and he comes up with custom settings for the tracking which are then tested until the car matches what you want to feel.
Laughed when I read the quotation for £350. Went to wheels in motion and paid £70.
Guys taking the ****
All this shows is so many people don't know the difference between a set up and a hunter alignment...
That is crazy. I do mine myself using the Axle stands and string method. Do my camber using a digital inclinometer mounted to two pieces of angle iron mounted on a hinge. Basic maths and can do it to what I want. Test drive it then change it again. Only cost to me is my time. Also very accurate to 0.1 degrees.
On mine I can change pretty much everything apart from corner weighting with just ~£40 of parts.
Absolutely. The difference between 'its all green m8' and a proper geometry setup.
Saying 'fast road setup innit m8' is also a bit weird because fast for one person isn't always fast for someone else.
I know the difference between a £350 set up and a kwik fit job is huge I was just pointing out if you have the passion and patience you can do it yourself. I spent the entire weekend setting my car up on my garage floor. I have two set ups. One for road and one for track (3 degrees negative on the front on a road car is horrible but fantastic on track for example).snip
Could you not afford it or something? Pft. It must be a pain to be poor.
Tbh when people are bringing in £80,000 Porsche 911's it would make sense that he is charging what he does at CG. But for my car it's more than excessive, however it was just a rough quote but they said if anything is seized (nothing is) it can cost a lot more, which is understandable as seized car parts can be a right ballache, especially when you cant put much heat on coilovers unless you want a nitrogen filled shock blowing up in your face.My £350 quote was simply for factory settings.
I would happily peg WIM alongside Centre mavity and WIM are certainly not the get it into green it will be fine type of chaps. The guy is just ripping it left right and centre.
Yup, I genuinely can't afford a £350 wheel alignment.
Does anyone know if Centre mavity gives a printout of all the settings for the car after it has been done?
Yes they do full settings sheets provided.
Haha your sig perfectly sums up the fast car & bike tunnel experience.WIM were very good with my S2000.
