On a Tuniq ????
What are you using to measure the temps ???
By under load are you talking about gaming or priming.
You must be in a very cold room.
The reason I ask is because my cpu is cooled the same as yours and at 3.6ghz idles at the moment at 31 degrees according to CoreTemp. I just ran Orthos and within 2-3 seconds it suddently jumps to 47 degrees. And going by past sessions after about 8 hours, the max recorded temp was in the high 50's. During gaming it obviously doesn't get anywhere near that hot.
Now this cpu uses a lot less power then my mates 3.3ghz quad. We have had this running in my rig as well to verify his temps. And under the same conditions, each core idles in the low to high 40's. And running Orthos (verison I have uses only 2 cores), the temps can be seen to hitting high 60's on the 2 cores not been used, and high 70's on the ones been used...almost approaching 80 on on of them. This ties in with reviews and other users I have spoken to.
So I cannot see how it is physically possible on air to see a max of 55 degrees when priming. Even Core2Duo's go higher then this for most people. And I have spoken to lots, including people on water and phase.
Extreme Systems : lots of people reporting high 60's when priming (watercooled) and up as high as 80. Using Tuniqs on full speed.
http://www.xtremesystems.org/forums/showthread.php?p=1901644
Same on the evga forums
http://www.evga.com/community/messageboard/topic.asp?TOPIC_ID=22894𣠪
The only thing I can conclude is that a lot of this depends on what you use to measure your temps. A lot of mobo's are very inaccurate though from what I read about the 680i it exagerrates temps upwards. I would have assumed that TAT or CoreTemp on an Intel mobo (which is what I am using) was accurate enough though, but maybe I am wrong. I also know lapping helps (maybe 4-5 degrees), but 55 degrees under load seems extraordinarily low.
Can you elaborate please as this is very important since I might be getting a quad soon.
thanks
