Swapping Motherboards
3 Apr 2012
Hello,
This is more of a general question. If one was to upgrade motherboard, is it as simple as "unplugging" the old motherboard and installing components into the new one?
If the same hard drives / boot drive etc. are installed will Windows work the same as before?
So basically can you just literally swap the motherboard and then plug and play?
I always tend todo a fresh install especially if your changing chipsets.
What are you looking to change to?
Well I recently put together my build , you can see it in my sig.
I was working on a budget, and the Motherboard - although very good - uses an older chipset as opposed to the 990fx chipsets that are around now.
I was looking at the asus sabertooth board. The reason for this is i'm hoping to begin my first (ever) overclock soon, when my Noctua DH-14 arrives.
From some information i've sourced, my older chipset may hinder my overclocking capability. Is this true?
Thanks for your response RJC
edit: I'd only be pushing for 4.00 maybe 4.2 on the overclock, perhaps I should stick with my current mobo (assuming it can handle that oc) until next gen CPU's come out?
