Swiftech Advice
27 Feb 2006
Normanton
Just got the Swiftech H20-220 Apex Ultra Watercooling Kit and a Swiftech MCW30 Chipset Waterblock just been reading through instructions and fitting barbs on.
Ive got a o-ring with the cpu block which is the GT version but it doesn't show you how to fit this in the instructions, anyone know if I need to use this and where to fit it?
Cheers
Cheers
If its a small o ring then they go on the barbs if its a large o ring then it will be a spare if you decide to split the plastic from the copper
I take it's the big O-ring you're speaking about (couple of inches across?). If it is, it's used to "bow" the base for using with concave IHS on some C2D CPUs.
Jokester
I just read the instructions that came with my gtx block and it too has the large o ring but it doesnt state what its for
Yeah it's used to replace the existing o-ring between the block and top. The spare ring is slightly fatter so that when you use it, it bows out the bottom of the block slightly so that it gets a better fit with the concave IHS that you get on some C2Ds.
Jokester
