Swiftech Apogee GT vs D-Tek FuZion REVIEW (Swiftech Apogee GT wins)
I said the same thing about there being two nights, but the article isn't well written.
I do know though that FCG (freecableguy) a very respected member of the Xtreme community (you should read his articles on the designed intel vdroop and GTLREF voltage tweak - amazing) was there and I'm sure there was no foul play.
He didn't actually supply any more force than the tests before, Gabe did say at the first night that the thicker O-Ring (bowed base) was going to be used, but the temperatures were not obtained as the board broke.
Obviously applying the same pressure to such a bowed block would stress the board more.
As I said, Scott at Xtremesystems is going a major test with a very well outlined methodology and I think they will be accurate enough as a guide line.
I woudnt take notice of tests done by a representitive of a product, would have been better if it was done by people who dont have anything to gain from it i.e. sales marketing because thats all it really is on their part.
I wouldn't have thought there would be more than a couple of degrees between the blocks as they are both top performers anyway.
welshtom said:
Here is a summary of the recent Fuzion, Apogee GT, and Storm test results that I've found to date...
Notes:
- If multiple mounts were done and results provided, I've indicated that and averaged the mounts/runs.
- Review the test methodology details and test result details by clicking the links
- All values are in deg C unless otherwise stated
- DT Values are from Core Temp to Air (unless otherwise stated)
- Quad core load temps as reported by core temp or TAT were averaged by the testers and sometimes the difference between cores was as much as 10 deg C. According to Philly_boy lapping seemed to reduce difference in cores significantly.
H20 Frag-monger (Apogee vs. Storm R2 vs. Fuzion)
CPU: X6800 OC to 3.8GHz
WC Gear: MCP-655, MCR-220
Test SW: TAT
DT Results: Apogee = 55.8, Storm = 51.7, Fuzion = 49.5
Winner: Fuzion beats Apogee by 6.3 and Storm by 2.2
Link: http://www.xtremesystems.org/forums/...&postcount=152
CPU: N/A - 30x30mm 100W die
WC Gear: Lytron chiller
Test SW: N/A
DT Results: N/A (C/W Curves)
C/W Results @ 1GPM: Apogee = 0.064, Storm = 0.059, Fuzion = 0.057
Pressure Drop @ 1GPM: Apogee = 2PSI, Storm = 5PSI, Fuzion = 0.5PSI
C/W Winner: @100W/1GPM Fuzion beats Apogee by 0.7 and Storm by 0.2
PSI Winner: @1GPM Fuzion has 25% and 10% of the pressure drop of Apogee/Storm
Link: http://www.xtremesystems.org/forums/...&postcount=304
Nikhsub1 (Storm G5 vs. Fuzion vs Apogee GT)
CPU: E6700 OC to 3.85GHz @ 1.56Vcore
WC Gear: 2xDDC Ultra, PA-120.3
Test SW: TAT
DT Results (avg of 3 mounts each): Storm G5 = 39.08, Fuzion = 43.06, Apogee GT (flat) = 44.54
Mount variation in DT: Storm 2 deg, Fuzion 2 deg, Apogee GT = 4.5 deg
Winner: Storm G5 beats Fuzion by 3.98 and Apogee GT by 5.46
Link: http://www.xtremesystems.org/forums/...1&postcount=10
FreeCableGuy (Storm R2 vs Apogee vs Fuzion vs Apogee GT)
CPU: X3220 Quad Core
WC Gear: D5, PA120.3
Test SW: Prime95 x4
DT Results (@150W): Apogee = 25, Storm = 26.5, Fuzion = 24, Apogee GT 24
Winner: Fuzion and Apogee GT very close and beat Apogee by 1 and Storm by 2.5 (@150W)
Link1: http://www.thetechrepository.com/showthread.php?t=85
Link2: http://www.thetechrepository.com/showthread.php?t=78
Link3: http://www.thetechrepository.com/showthread.php?t=84
Philly_Boy CES Showdown Part 1 (Apogee GT vs. Fuzion)
CPU: X6700 Quad Core OC to 3.6GHz @ 1.425Vcore
WC Gear: MCP-655, MCR-320
Test SW: CPU Burn 5
DT Results: Apogee GT (Bow?) = 42.1 (1 run), Fuzion = 38.2 (avg. of 3 runs on 2 mounts)
Winner: Fuzion beats Apogee GT (Bow?) by 3.9
Link: http://www.xtremesystems.org/forums/...0&postcount=84
Philly_Boy CES Showdown Part 2 (Apogee GT vs. Fuzion)
CPU: X6700 Quad Core (lapped) OC to 3.466GHz @ 1.5Vcore
Test SW: CPU Burn 5
DT Results: Apogee GT (flat) = 41.7, Apogee GT (Bow) = 34.1, Fuzion = 37.3 (using D-Tek mounting hardware and methods)
Winner: Apogee GT (Bow) beats Apogee GT (flat) by 7.6 and Fuzion by 3.2
Link: http://www.xtremesystems.org/forums/...d.php?t=130142
Shamino (VR-Zone) (Apogee GT vs. Storm Vs. MCP-05 Pro)
CPU: X6700 Quad Core OC to 3.615GHz @ 1.7Vcore
WC Gear: D5, 2x120mm Rad?
Test SW: CPU Burn
DT Results (from Asus Probe): Apogee GT (flat) = 58, Storm = 60, MCP-05 Pro = 56
Winner: MCP-05 Pro beats GT (flat) by 2 and Storm by 4
Link: http://www.vr-zone.com/?i=4476&s=1
Budwise (Storm G4 R1 vs. Fuzion)
CPU: E6600 OC to 3.6GHz @ 1.45Vcore
WC Gear: MCP-655, PA120.3
Test SW: Orthos
DT Results (from CoreTemp): Storm = 54, Fuzion = 51
Winner: Fuzion beats Storm by 3
Link: http://www.xtremesystems.org/forums/...1&postcount=30
Philly_Boy (Apogee GT vs Fuzion)
CPU: E6300 OC to 3.7GHz @ 1.6V Vcore
WC Gear: MCP-355, PA120.3
Test SW: TAT
DT Results (from CoreTemp): Fuzion = 37, Apogee GT = 34
Winner: Apogee GT (Bow) beats Fuzion by 3
Link: http://www.xtremesystems.org/forums/...7&postcount=54
David D. at CoolingMasters.com (Rosco?) (No Fuzion tested)
CPU: E6300 OC to 3.01GHz @ 1.59 Vcore
WC Gear: AquaX150Z, MCR220
Test SW: TAT
DT Results Original IHS (Core to Water @ 350lph): Apogee = 47.1, Apogee GT = 44.4, Apogee GT (bow) = 42.1, Storm = 49.6, MP-05 SP = 48
Winner: Apogee GT (bow) beats Apogee by 5, GT Flat by 2.3, Storm by 7.5, MP-05 by 5.9
Link (translated): http://translate.google.com/translat...language_tools
My conclusions so far:
Given the fact that all tests by the same testers varied by up to 2-4 degrees just by remounting or doing another run and the fact that all blocks are typically within a few degrees of each other (and often much less) I would say it's impossible to declare any block definitively superior to another so far.
Given this, I think any testing without multiple and equal number of remounts for each block can be very misleading. For example, Nikhsub1's tests show that the Fuzion could win by 4 degrees or lose by 1 degree to the GT depending on which mount and run you used to compare. With the mount making as much as a 5 degree difference on blocks that typically only differ by a couple of degrees it makes drawing conclusions from limited runs/mounts dubious at best.
The only thing that everyone seems to agree on is that the Fuzion flows significantly better than any other CPU block giving it a distinct advantage in multi-block loop performance.
BTW, if I've made a mistake in summarizing the results or there are other tests that can be added to the list above, please let me know. Keep in mind that if multiple runs or mounts were reported, I averaged the results of those runs/mounts in the summaries above.
