Ok guys I have a bit of a problem I hope you can help resolve. In the picture below I show the reservoir without its mounting bracket:
The pump is mounted in a 5.25 bay and the 120.2 radiator is in the bottom of the case. Once the mounting bracket is on the first bit of tubing to the top of the pump kinks as it nearly hits the side of the case. Try as I may I just can't seem to find anywhere to mount the reservoir.
Does the reservoir need to be above the height of the pump or is that preferable?
Any help on positioning the reservoir will be appreciated as I'm close to making the final assembly now.
The case is a Lain-Li V200B Plus II:
