Swiftech Watercooling Kit Question
16 May 2006
Dubai
http://www.overclockers.co.uk/acatalog/Swiftech.html
Can the Swiftech H20-120 Premium Watercooling Kit's pump be easily dis-attach from the 5.25 bay unit?
I'm thinking of getting that, dis-attach the pump and replace that reservior with a 5.25 clear version. It's going into a Aspire X-Qpack case with window.
I'd rather get all the required from that kit to fit and add the reservior I like than to source out single parts.
Edit: also, will the 5.25 bay unit from that kit fit behind the front bezel of the Aspire X-Qpack?
Not really. The connectors are quite hard to get off, but I would question why you would want to do this? The reservoir works well, is easy to bleed. If you want bling, get the clear res, block all the holes and fill it with water.
Oh no... I'm just wondering because the Aspire case has 3 clear window, with the 5.25 bay from swiftech, it looks "naff", although it's very compact.
Also, the aspire only have 2 5.25 bays and a 3.5 bay.
Looks like I'll be getting each parts custom then.
If so,
what's a good 120.1 rad? The Black Ice Pro or the swiftech 120.1 on sale here on OcUK?
I'm setting it to cool a Conroe E6600 and MAYBE loop the x1900xt in too, any advice is welcomed!
