Guys this hasn't worked
I'd post a screen shot but after apple key + shift + 4
I don't know where to paste it to? Something similar to windows paint?
I use the Image Uploader Widget just drag your image to the dashboard widget and it autmatically uploads to imagehosting site and puts the link to the image in clipboard. So just paste link and youre away
About macfuse illa ssume youve installed the latest version. the ntfs-3g installer ive directly linked here http://downloads.sourceforge.net/catacombae/NTFS-3G_1.5130u2-stable-catacombae.dmg?use_mirror=osdn
install that and you should be good to go.
edit: oh yes and you should reboot too after installing.
did another install and after the reboot got an error message about not being able to mount the XP drive and now my XP boot camp drive has vanished from my desktop... Best way to uninstall is?To unistall ntfs-3g open up the .dmg file and inside there should be another file called "Uninstall NTFS-3G.command" run that and it will unistall it.
To unistall mac fuse go to the Mace Fuse preference pane and theres a button 'uninstall macfuse'.
hope that helps
