At the moment I've got Speakers connected to the mobo line out and then I use the case front panel to plug the headphones in/out when needed.
I'd prefer having both connected all the time and just switch between them when I need to using windows 10/11 speaker control.
So for example if I switch to headphones, the speakers will shut off and vice versa.
Both headphones and speakers use a standard 3.5mm audio cable.
I've got a MSI Z490i Unify, is this possible or do I need to buy an Aux switcher?
