Sym XS125-K
22 Sep 2008
Liverpool
Hi,
I bought the Sym XS125-K bike just before Xmas while it was on their free insurance offer... I managed to get a lock, helmet and jacket thrown in too, so I'm all up and running on my first bike. I'd like to know a bit more about the bike, but cannot find ANYTHING about it online. A couple of reviews but no real details.
The manual that came with it looked like a photo-copied print-off, so I guess you can say that there's very little support. I'm familiar with Cars and the basics of their innermost workings, so was looking forward to being able to work on the bike, for things like servicing, but I can;t find anything.
I've been advised that it's a copy of another more mainstream bike, so I was going to look for some documentation on that.... but I don;t know what it's a copy of.
Anyone any ideas?
many thanks
mike
As above, looks like a YBR copy.
See if you can find a forum based on the YBR's CB's etc or find a Hayne's manual online and have a look to see how similar they are.
Its a standard 125 so easy enough to get advice when it comes to tinkering with it.
Looks a lot like the Yamaha YBR 125 to me, might be worth trying to find a book for that?
The guy who parked next to me at work has a 2010 model YBR and it's similar, but not the same. I'm interested in the hosing because I have a couple that are just vented to atmosphere and hanging loose, which doesn;t seem right to me. The bike rides fine,a nd there's no oil or fuel coming out of them, so I'm trying to understand what they do.
When it's stopped raining I'll get a photo and post that up...
I'd like to know where to check the oil on this. The break fluid is obvious where that is, but there's no dip stick. I appreciate that these smaller bikes don;t have dip sticks, so how do you check oil levels?
There may be a small circular viewing window near the oil filler that you can use to view the oil level.
At least one of the 'tubes' will be an overflow pipe attached to the bottom of your carb to prevent flooding and there should also be one or two breather pipes for the engine. It's completely normal on all bikes to have these loose 'tubes'.
As it's a cheap Chinese bike I'd expect the oil level to be checked using a dipstick. If so, take a look around the bottom end of your engine and it should be obvious which cap is your dipstick.
If not, there'll be a sight glass at the bottom side of the gear box.
Wonderful guys +trust
Thanks for the advice. I'll have a look at the bike when I get it out next..... when this rain heads off.... :(
FYI, there is a dip stick on the bottom casing - I'm assuming that is the gearbox.
Likewise there is a drain plug at the bottom of said casing. I finally found the manual and had a read... Surprisingly all the detail was in there, despite it being a rather flacid looking publication.
If anyone is ever in any doubt about these bikes, I've been delighted with mine over the past 6 months. It;s a shame that the screw heads aren't actually chromed, as they'd mostly rusted.
Good points:
Cheap to buy
Cheap to run
Fun
Came with insurance
...and jacket
...and helmet
...and lock
...and a half tank of petrol!!!
Not quite so good:
Takes some getting-the-knack-of starting it
Neutral can be hard to find
Top Speed says 70... comfortably it's 50 though
Rusts...
Bike went in for it's first FREE service a few weeks ago. They adjusted the brakes, which threw me (almost quite literally) the first time I rode it after. The garage I bought the bike from "The Scooter Centre" in Fazakerley have been really good imho. One problem developed a couple of days later - the clam shell that clamps over the handlebars that houses the throttle has become un-anchored and now turns freely. This means that when I rev the whole throttle assembly moves.
When I got home I removed the entire assembly off by removing the two screws and then un-clamping the "throttle-clam" to see if anything was broken inside. Nothing looked broken, so I tried tightening up the screws... No change. Throttle plus the clam that the throttle is anchored to still all move as one when accelerating.
Next I tried wrapping some electrical insulation tap around the handlebars to increase the diameter of the handlebars, and give the clam something to "bite" into as I tighten up. Now I couldn't tighten the clam up tight enough for it to fit snugly. Grr.
In desperation I took a detour on the bike on my way home from work, and they immediately looked at the problem, and ordered a replacement part, all under warranty!
Bike's being dropped in tomorrow AM, and should take about 30 mins to fix. Still very happy with my XS125-k. I'll shove some pictures up of my pride and joy...
I can't wait to do my full bike license. If this is what a scooter/moped class bike is like, I'm sold for life. I've been driving for 20 years nearly, and I've never had this much satisfaction from a car.
If you want to get into the community of biking, which to be is a big part of it all, head out on a Wednesday, either up to Southport or The Scotch Piper which is in Lydiate. You'll meet loads of guys and girls, all ages, who ride all sorts of things, really adds to the experience in my opinion :).
http://www.chinesemotorcyclepartsonline.co.uk normally lists anything you'd need for a chinese bike however only one Sym model is listed.
This might be the manual that you already have: http://www.sym.com.tw/admin/upload/...5-K.pdf?PHPSESSID=8d7ab7912872d593ee70722d83b which gives you the basics but nothing indepth.
I googled for Sym owners club and found two forums but neither have a section for your particular bike.
It'll have a chinese clone engine that will be very similar to Yamahas engine.
Nice one. As the bike's new, It'll be going back to the place where I bought it. I wan't to keep up the warranty as it's valid for 3 years. The bike's worth next to nothing second hand, so I want problem free motoring for as long as I can. If however I keep the bike beyond that, the link looks awesomely useful, so thanks-a-million for that. It gives me an idea of prices of things which is always useful.
The manual is the same as the printed one that came with the bike. A+ searching skills my friend.... :)
The garage has replaced the Clam part under warranty, and all is well again. One of the mirrors fell off shortly after, but I managed to park up and retrieve it before someone ran over it. The sticky back to the mirror wasn't sticky enough evidently, or just wasn't making good enough contact with the handlebar attachment.
up to 1600km on the bike so far, the longest trip being about 20km. I'm really starting to get the bug! I've enjoyed coming into work since I got the bike, which is unheard of!!! :)
I had a Sym xs 125-k for a short while. If you get the road for it, you can push 110Km/h. But it's a struggle to get above 105.
As said above, it's very similar to a Yamaha YBR though not exact, most YUBR parts wil lfit, but some (like the exhaust) will need some tinkering.
Most bikes will rust if left out in the rain. A tip an old biker friend of mine suggested was, to use baby oil on the chrome work. Makes it shine like the sun, but also protects against rust. (**** will stick to it tho).
I recently replaced mine with a Lexmoto Lowride :D
110km/h!!!!!!!! No way. You must have been a quivering wreck when you got off!!!! Mine vibrates and feels like parts are going to start dropping off when you get to 85km/h - I've not been above that yet....
It was a real push to get it there. Give it time to run in, and use the super unleaded. I always thought it was a myth that super was better. But when you next fill up try it. You will notice the difference
I'm not sure about using Super. It's a different, higher RON rating, which could POTENTIALLY damage the piston head. I'll stick to the regular stuff while the bikes under warranty
What was your like for resale value? What did you pay (new?) and what did you get rid of it for, and after how long?
I picked mine up new for £1600, and that came with insurance, helmet, chain, L Plates and a half tank of petrol. What would I reasonably expect to get for it after 2 years of ownership? I'm hoping to keep it till next year when my CBT expires, and do my full test then.
I was thinking it should be worth around the grand mark, but I'm not sure as you just don't see them for sale, or at least I haven't!
I always figured higher Octane ratings meant the fuel was less likely to damage the pistons?
I haven't resold mine, I gave it to the girlfriends dad to tinker with as he wanted a bike to mess around on, having last owned one over 40 years ago. (It's always good to be nice to the inlaws). Could have make around 500 or so though, had I got it repaired before selling.
Resale value obviuously depends on quality of the bike, I would be surprised if you would get more than maybe 600-700 though; and only if the bike is in good condition, with low mileage.
Problem with most asian makes is that they are cheap to produce, and have a bad rep. So most people will avoid a second hand one.
I purchased mine for around £400, but it needed a good bit of work done to it as the previous owner never really looked after it.
Replaced it with the Lexmoto (http://kickstart.lexmoto.co.uk/DFE125L.php) mostly because the Sym had a few issues starting to creep up.
Needed a new chain and sprocket, and tachometer started to fail and was a little hard to shift gears. (The bike was a 2008 model).Not big issues; but enough to make me want a shiny new bike. Plus the new bike is a lot smoother to ride, and as it's brand new. I have less issues to worry about.
The Sym is a good learner bike for sure, and based on its resell price you shouldn't have too much hassle shifting it. Just make sure you look after it, they have a tendency to rust a little if you aren't careful.
Just a quick update - finally ventured a little further afield than home-work. On Saturday I took advantage of the belting weather and went to see my parents in Droitwich - on the Sym :)
Due to the provisional nature of my license, motorways are off-limits, so it was A-roads all the way. A couple of stretches of national speed limit, as well as lots of hills and stuff to really open up the throttle and see just what it could do.
The bike handles really well. Sometimes I found myself understeering through some of the bends, but in the main the bike was ok. It bimbles along quite happily at 50 mph, and with a tail wind, steep downward hill, and not too strong a headwind, I managed to get up to 67mph before bottling out.
The bike feels short on power when opening up on open road - it's a 125 though, so I guess that's the reason people move up. I get it now. On hills, the bike struggled to pull my heavy load up above 50 mph - but there is 17.5 stone of me, so that's no surprise really.
All in in all I'm delighted with the bike. It's opened up a new dimension to me.
Liverpool to Droitwich, via Chester, Whitchurch, Shrewsbury, Telford, then Kidderminster was all very well, but at nearly 4 hours (including a stop for a drink and wiping the dead flies of the visor) it was a long trek.
https://maps.google.co.uk/maps?sadd...dPGM-lwSDHrkva4KGZ_Vg&dirflg=h&mra=ls&t=m&z=9
Coming back, I just did Droitwich-Kidderminster-Wolverhampton-Whitchurch-Chester-Liverpool, which I managed on the remainder of the tank, and this was in 3 hours door to door, which was about the time that google said it'd be.
https://maps.google.co.uk/maps?sadd...hc_bwTcQg&oq=L4&dirflg=h&mra=ls&t=m&z=9&via=1
Petrol, the bike used 20.7litres of fuel - I really was running on fumes by the time I got to Birkenhead, and cost me 15.11 to refill. I'd done 367 km round trip, including going to and from work (21km) on Friday.
15 quid to get from Liverpool to Droitwich, and back again is the best I've managed in a LONG time. I worked out that (using UK Gallon = 4.54609 litres) the bike has averaged 50.13 mpg over the weekend, which for a commuter bike, pushed as fast as I can make it go, for nearly 7 hours is pretty good by my estimations.
I'll check the oil levels at the end of the week. I'm delighted how the bike's performed, and I'm iching to get my full license now so I can have a go on a bike that the trip doesn't seem quite such hard work.
Comfort - I must admit - 3 hours sat in one position was getting somewhat uncomfortable. I found that the bike wasn't slipping into gear quite so easily, but I'm not sure if that's more to do with me just being tired and pussy footing with the gear shift. It was certainly a rude awakening having to pull away in 1st, try switching up, miss, then drop back down to first to then try going up again. Just part of my bikes "character" I guess....
