Synology DS211J Help
16 Apr 2007
UK
Hey all,
I bought a Synology DS211J after being recommended to it by a few members of this forum.
I opened it up expecting to find a massive manual, but all I got was a disc and some cables - after a few hours of tinkering, I think I've sort of got the hang of it...
However, I'm trying to install SABnzbd+ on it - but have been unlucky :( Also it looks like the Synology forum is less than useless as I, as well as others, have had no replies for ages :(
I downloaded SABnzbd from:
http://www.mertymade.com/syno/
I downloaded the zip, unzipped and uploaded the .spk file to my DS211J.
It did its thing and I clicked Run. However, when I go to the IP address shown below it doesn't load anything - It just loads for about 2 minutes and says it took to long to respond (A sort of 404 page).
Any ideas on how to get this going?
Thanks,
Marky
Hi,
What is the response when you log on to the NAS via SSH or Telent and run the PS command on SAB*?
Sounds like it either hasn't started for some reason, or it has but on a different port to what you are putting in the browser.
Go to /YOURSHARE/@appstore/sab/SABnzbd/config.ini and have a look at what it is running on.
Hi,
I have no idea how to do any of that :p
Where will I find that?
Hi Marky,
You're going to need some Linux / Unix command line knowledge to get SAB running properly.
Can I suggest you have a peek at the following pages to get some hints...
http://kevin.vanzonneveld.net/techblog/article/install_sabnzbd_on_your_synology/
And you might have looked here already...
http://forum.synology.com/enu/viewt...+upgrade&sid=d4ea54916a4d553679f4a1d0017966e5
Regards,
Simpic
I've taken a quick look over it - still pretty confused :(
Starting to wish I got a ReadyNAS now... They make it look a lot easier than this :p
