Hi all,
I'm just setting up my new Synology DS215J. I've installed a couple of Seagate 750GB HDDs that I had in the drawer for now. The setup has worked beautifully and I'm just copying my files over to it now.
I noticed that the DiskStation formatted the drives and installed it's own operating system. However, I'm not sure what file system it uses (pretty sure it's not NTFS)? Whatever it is, does it mean that the drives can now only be read if in a Synology DiskStation?
Also, the two drives I've used are getting on a bit now (2007-2008). So would want to replace them with some new drives in the not too distant future. Do I just copy the files off, swap out the old drives and start setup again as new?
Finally, I assume it is mirroring everything on to both drives? If one drive were to fail would I still be able to access the other?
Sorry, I'm new to this and would appreciate some help.
Thanks.
Thanks.
