Hi all,
I have just had my new custom PC delivered (well collected it from local depot) pleased with the build and quality however it won't power on. Here's what does happen:
Upon plugging it in and turning the PSU on (I also get that little sound where it's drawing power) I get lights temporarily on the keyboard bottom and mouse however they don't stay on. I can see that power is going to the GPU as there is a constant light on it but no other lights are visible. No standby light on the PC (not sure if the case has one anyway) the PSU isn't working (fan not on)
I've checked the connector going into the mobo with no concerns but I'm not an experienced builder hence the custom configured purchase. I also got the check list advising various drivers had been installed so it suggests it worked??
Is the power button faulty? What should I be looking out for? I really don't want to have to send it back!
Help would be greatly appreciated!
Jon
Jon
