System Boot Problem
5 Dec 2009
Near OCUK
Hi all,
Have just put together a new rig (i5 25000k, AsRock z68 Extreme4 Gen3, 16GB RAM, 7970, 850W PSU, Corsair 800D case and Custom Water Loop) and for the first time in approx 5-6 builds I've hit a problem I just don't know what to do about! Hoping you guys will be able to help as you've helped so much in the past.
The problem is, I've connected all the 'Front Panel' (reset switch, power switch, HDD led etc) into the system panel on the motherboard. However, none of it seems to function whatsoever! I've checked over the MB to make sure everything is in the right way, and even tried the other way, but nothing! Powering on directly from the Motherboard works, however, nothing appears on the screen!? The motherboard then seems to power itself down and do nothing...
The last readout from the Dr Debug is an A3 - which corresponds to: 0xA3 code as IDE Enable
Anyone else had either of these issues?
Many thanks!
Can be ignored now, stupid mistake! Had accidentally pulled the connecting cable out of the front of the case....doh! This seems to have also fixed the A3 error as well. On with the install of windows!
