System build - £700 gaming setup
30 Aug 2011
I thought i'd post you some pics and comments as i built my new system which i had discussed with you previously...
Its the first time ive posted something like this so sorry if i make any errors or miss anything!
The kit - £700 worth
The case - Coolermaster - didnt come with a 3.5 - 2.5 adapter for my 2.5' SSD :(
Power supply fitted at bottom
Bluray drive fitted and front view:
The motherboard - MSI P67A GD65
Memory - Kingston hyper x 8gb
Motherboard and processor fitted in case:
Cpu Cooler - way bigger than ive ever seen! fan was i ***** to fit to the heatsink, no instructions included.
As you can see the cpu cooler only just fitted in the case with about half an inch clearance!
Cable management not my best strength!
Gigabyte GTX560ti fitted, needs 2 pcie power plugs. couldnt use the HDMI connection as it was too close to the edge of the case, silly design fault by coolermaster!!
all fitted and powered up to see if it works ok:
Relieved to say its all working and windows 7 installing... this is how it looks in my cabinet at home!
Any questions please feel free to ask!!
Do you have a photo of the back? I'm interested in the HDMI port problem!
here we go....
You will see it is a mini HDMI but they have put it so close to the edge that the adapter supplied with the graphics card wont fit in the hole. I am going to shop around for a mini hdmi to hdmi cable and hopefully will find one that will fit....or, as i have just read, apparently DVI and HDMI are exactly the same with the only difference being HDMI carries audio as well so i probably wont bother!!
I love the idea of the pc in a cabinet, I'm looking around for something like this myself. Where did you get it? can you remember how much it set you back?
Oh, and the PC isn't bad either :p
I had a helluva job to find one adequate for the job. In the end i imported it via a website but it was a few years ago now and i cant remember where it came from. It cost me around £450 at the time but it is superb quality and is solid as a rock. Even with the 5.1 surround system and sub blasting out there is no vibration and the wood is still as good as new. If i do think where i got it ill let you know....
