10 Aug 2007 at 20:08 #1 speedyj speedyj Associate Joined 19 Mar 2006 Posts 633 Location Suffolk Hi all, I'm looking to build a rig using the Athlon 64 X2 Dual Core 6000+ Any advice on what components to use with it please?
10 Aug 2007 at 23:05 #3 speedyj speedyj Associate OP Joined 19 Mar 2006 Posts 633 Location Suffolk budget up to £400 and will be an all round workhorse rig.
10 Aug 2007 at 23:16 #6 speedyj speedyj Associate OP Joined 19 Mar 2006 Posts 633 Location Suffolk Gonna go AMD but would like to know which memory, mobo, PSU etc would be better with this CPU. I'm using a P4 3.0 ATM and its getting a little slow.
10 Aug 2007 at 23:25 #8 speedyj speedyj Associate OP Joined 19 Mar 2006 Posts 633 Location Suffolk My current rig is a Dell (I know, I know!!) Its BTX format by the way. I can reuse the GFX, HD & Opticals but that about it i would imagine.
10 Aug 2007 at 23:52 #9 speedyj speedyj Associate OP Joined 19 Mar 2006 Posts 633 Location Suffolk Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940/AM2) £13.99 Antec Sonata III Piano Black Quiet Case - EarthWatts 500W PSU £60.99 Crucial 2GB (2x1GB) DDR2 PC2-5300C5 Dual Channel Kit (CT2KIT12864AA667) £44.99 AMD Athlon 64 X2 Dual Core 6000+ 3.00GHz (Socket AM2) - OEM £83.99 Asrock ALiveSATA2-GLAN (Socket AM2) PCI-Express DDR2 Motherboard £34.99 Sub Total : £238.95 How does this look?
