System Build - any advice?
26 Aug 2009
It's been a while since I've put a hw spec together, I currently have a coolmaster case with 2 x 750gb hdds, 850w PSU, dvd-rw...
I'm thinking of replacing my broken 8800 ultra, q6600 and MS-7325, 4gb ddr2 ram for.. (see attached image)
Is this all I need to get crossfire working and to overclock the processor to 3.8/4ghz? And is the memory/ssd/cooler/mb a good choice?
What if bought two lots of the RAM to get it up to 12gb.. here I was looking at 12gb packs thinking the timing was slower. When I could just double up the bundle I've got!
edit. Is my 850 PSU going to have the connections for two v/cards I wonder.... I guess adapters are usually supplied
psu will need 4 pci-e power connectors, dont think the 5870 needs more than 2 per card.
wouldn't go with the ssd yet, i'd wait til win7 has been released and see what ssd changes are made afterwards.
any reason your getting 2 5870s ?, aside from the fact you want crossfire ?
Thanks
Are you thinking without a bunch of monitors it's a little over the top? I'm only using a 24inch benq and 21inc viewsonic.
I was thinking of additional performance for games and 3d rendering suites.
