System build problem !
11 Mar 2004
I've just built a PC based on this
Asrock Conroe945G-DVI (Socket 775) PCI-Express DDR2 Motherboard
GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit
Antec NeoHE 380W Modular ATX2.0 PSU
Western Digital Caviar SE16 320GB 3200KS SATA-II 16MB Cache - Intel
Celeron D 356 3.33GHz (LGA775)
Its just for web browsing and email etc, so no great performance needed.
Reused case, DVD drive etc etc
Problems started when i turned it on. Fans spun on heatsink, PSU but no life other than that. No beeps, or attempts to light the case power lights etc.
I tried a few things like removing the CMOS battery for 30 mins, and then using the clear CMOS jumpers with no luck. In fact, things got worse because now it powers up, then turns off after 20 secs or so.
Pointers ? Somethings DOA fairly obviously but CPU, Motherboard or PSU ? Or a combination ?
Unless its the case itself causing the problem. The donor case did come from a knackered old PC, but its just a case after all.
Help !
Nah, case will have nothing to do with it however it could be the way you have mounted it in the case (Could be shorting or something). Have you connected both the 24pin connector AND the ATX12V 4 pin as well? If you have then I would just try reseating everything first, try one stick of RAM and alternate etc and then just strip the system down to barebones- mobo, cpu, psu, ram and gpu and see what happens then :)
i see you suggest the power connectors everytime now due to me trigger! Heh just wanted to make sure u got a big thanks, you saved my sanity and now the pc is working a dream!
Hehe :D Your welcome mate- glad I could help :) It's always nice when it's nothing major that stops the PC working- sending different components back and forth for RMA etc can prove tiresome so it's always good when it's just an extra power connector that needs plugging in or a RAM reseat that gets it going :)
Yep tried all that. Both power are connected, reseated the memory, swapped them around tried just one, tried with just the basics etc etc
Hmm, could try reseating the CPU and graphics card. Also make sure the heatsink fan power cable is connected securely because if the system thinks there's no fan there then it will cut out. Check for any excessive heat on the CPU at boot up as well by holding your fingers against the heatsink- although I doubt it will get too hot within 20 seconds for it to cut out, I guess anything's possible :D One final thing I can think of is trying to boot it outside the case to eliminate any shorting problems etc. Good Luck :)
Its got integrated video so there's nothing to do there, and i did reseat the CPU and check the fan.
Didn't try it outside the case though, but the case has been OK for years.....
I'm going to get the motherboard RMA'd i think, can't think of anything else to do really.
I've spoken to a very nice chap at OcUK, got the board RMA'd.
Just to cover all bases i've bought a new case as well. The old one was a little bit tatty anyway.
