System build update Thoughts?
29 Jul 2013
so this will be my new system i was just wondering on what you guy's think i have posted a lot on here because i keep changing my mind and stuff i just want some advise. i know that a 1200w power supply is overkill but i want the best of the best this is about components that will last for at least 2 years.
CASE - Corsair 800D - £214.99
Motherboard - ASUS Rampage IV Extreme - £305.98
CPU - i7 4930k - £455
WINDOWS 7 Professional - £150
SSD - Samsung 500gb EVO - £289.99
GPU - MSI GTX 780 - £500
PSU - Corsair AX1200i - £200
CPU Cooler - Corsair h100i - £88.98
RAM - Corsair Dominator Platinum 32GB (1866MHZ) - £294.99
PSU CABLES -AX 1200 RED CABLES - £61.50
HDD - Seagate Barracuda 3TB - £85
Lighting system - NZXT HUE - £29.96
Mouse - Logitech G600 MMO Mouse - £48.99
TOTAL - £3256.23 - $5111.63
You've made several threads with pretty much the same spec, you don't seem to actually want advice or suggestions. :confused:
If you've decided that's what your having, then just buy it rather than asking what we think.
If you genuinely want advise just update one of your previous threads. :)
If you are going that hardcore then you might as well setup a full water cooling loop.
The spec itself is overkill in quite a few areas but if you got the money for it then go ahead, you won't be penalizing yourself in anyway.
Could be spent better, you don't need all that to cover you for 2 years. A simple i5 setup will manage 4 years+ without problems.
Also this.
