- 8 Sep 2011
Hi i ordered a pc using the configurator using the following spec:
Case: Thermaltake Level 10 GT Visionary Full Tower Case - Black
CPU: Intel Core i7-2600K 3.40GHz Quad Core Processor
Overclock: Stage 5: MAX OC OF ENTIRE SYSTEM - (CPU, RAM Graphics all OCd to maximum 24/7 Stability)
CPU Cooler: Akasa Venom CPU Cooler
Motherboard: Asus Maximus IV Extreme-Z Intel Z68
RAM: Corsair Vengeance 8GB 1600MHz C8 Memory Kit
GPU: OcUK GeForce GTX 580 1536MB GDDR5
GPU 2(SLI): OcUK GeForce GTX 580 1536MB GDDR5
HARD DRIVE:Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache
BLU-RAY/DVD DRIVE: LG BH10LS30 10x BluRay-RW / 16 x DVD±RW Drive
Power Supply: Corsair Pro Gold AX1200W
Operating System: Windows 7 Home Premium 64-Bit
Network Adapter: TP Link 300Mbps Wireless-N USB Adapter
Fully Cable Managed.
Now i'm just wondering will everything be installed and ready to go or will i have to install anything myself?
I heard somewhere that they don't install some parts.
As in Cooler' Gpu's' etc
I thought when ordering using the configurator they would install everything for you so that it would be ready to use kinda like prebuilt?
If one of you guys from the forums or an employee of overclockers could clear this up that would be great.
Thanks.
Thanks.
