My system components are;
- Gigabyte GA-B85M-D3H
- CoolerMaster Masterliquid Lite 120
- 4 x Corsair AF120 Quiet Edition (3-Pin, 120mm, 1,500RPM)
I am currently downsizing from ATX to Micro-ATX and I have a question in regards to case fans and fan splitters. My motherboard has;
- 3 x SYS_FAN headers.
- 1 x CPU_FAN headers.
The CPU AIO (CM Masterliquid Lite 120) will take up the CPU_FAN header and 1 of the SYS_FAN headers leaving me with 2 SYS_FAN headers to power 4 case fans. To get around this issue I am planning on ordering;
https://www.overclockers.co.uk/ek-water-blocks-ek-cable-splitter-4-fan-pwm-extended-wc-9cq-ek.html
Please correct me if I am wrong in my presumptions, the fans I have are not PWN capable so I am not fussed about automatic fan control however I would like to have the ability to control the speed of the fans via the Gigabyte desktop application. My thought is, as I will be plugging the EK Water Blocks Cable Splitter into one of the SYS_FAN headers (allowing me to control the speed), the 4 fans direct into the splitter and of course the molex connector to power them.
Will this work and will I be ok plugging 3-Pin case fans into the 4-Pin EK Water Blocks splitter? Thanks.
