System does not start
14 Jun 2017
Hii
I've Just changed my old CPU ( 4 Core ) to ( FX-8350 ).
My system used to run perfectly , just changed the CPU , it started for few seconds , then 3 beeps came , then the system stopped from booting. I noticed the Case indicator light was flashing , 1 second on , 1 second off.
i checked the connections, recontacted everything again, still nothing. When I close the PSU for few seconds, open it again, the system starts for milliseconds , just see a blue light and as the fan will start then again no power.
what else can I do?
I tried already clearing the CMOS
did not help
my bios is K.5, the latest
but I was thinking , could it be the motherboard just died
how to know that?
or maybe something wrong with cpu?
what other things can stop the system from powering up?
also what those 3 beeps mean?
system specs:
mother board : MSi 990fxa-gd65gda
Ram: 8GB Kingstone
GPU: Gigabyte Radeon 460 4GB
OS : Windows10 X64
450 watt PSU
What's the brand/model of the PSU?
The FX-8350 has a TDP of 125W - your 4 core(?) may have been considerably less. The PSU may be struggling with initial boot - try the 4 core again.
Thank you all For your all help
I tried the old CPU
still the same problem
but I found the problem
its the " ATX 8-pin Power Connector: JPWR2 "
if I remove the connector the system works but of course not the CPU
when I use the connector again no power, only a little spark after powering of the PSU ( Corsair ) and on again.
is this a motherboard problem
or PSU?
Could be lots of things in that old PC.
Worn out motherboards or PSU, even bad BIOS battery could have went dead during change.
(What's the precise PSU model?)
Might need also clearing CMOS to defaults to get it recognize new CPU.
Though if old CPU doesn't anymore work, that hints toward other cause.
I don't know the the PSU model
But as I said before , I already tried the old CPU , same problem
Ill try another PSU , hope it will work , cuz either I guess means the motherboard problem
The PSU make/model will be written on it somewhere along with a sticker with the output amps on each of the voltage rails.
its confirmed
its the motherboard
the ATX 8-pin Power Connector: JPWR2 is the problem , tried brand new cooler master PSU same problem
