System hang after bios flash
4 Oct 2007
Belfast
Here it goes..
flashed the bios of a sapphire PI motherboard, went ok, reset the CMOS, that was good, changed my hdd boot order (to boot from sATA, I have an IDE drive too that it defaults to) and restarted.
HOWEVER
Just after the POST, when the message "verifying DMI pool data" comes up, the system hangs. I dont think its a problem with the DMI data, just an instruction after it, but seeing as i have no idea what happens then, I cant determine where the problem is. Twice it got as far as XP, then hanged, which gives me some hope.
Also, even with hdd boot completly disabled and booting a system disc from floppy or xp cd (for bios flash or fdisk) , it still hangs around 14/15 times.
Tried reflashing the bios with a new downloaded file - no effect. Tried writing a new boot sector with recovery console (when the system stayed stable long enough to load it that is) - no effect. Tried writing a new MBR with recovery console - no effect.
I don't know whats wrong with my poor system!! Looks like I'm going to have to buy a new mobo/proc, but I'm poor and dont want to spend the money when I've an engagement ring to buy..
So if theres anybody whos had this problem, or at least knows what the sys:(em is doing after it verifies the DMI data which could give me an indication of which bit of the comp is bummed, I'd be most grateful!!!
Cheers,
Dave
PS
Sapphire Pure innovation A9RX480 S939 Mainboard
AMD Athlon 4600+ X2 64
2x1GB crucial RAM (guarenteed compatibility using their compatibility tool)
160GB Samsung spin point HDD (main) (sATA)
80GB Maxtor diamond HDD (IDE)
Seasonic S12 430W PSU
LG DVD writer
an old FDD
unplug your ide drive, if that sorts it then its a problem with the ide wanting to boot before the sata even tho you have set prioritys
also make sure sata mode is set to ide no ahci
Tried and failed.
It managed into windows again, working ok, but gradualy got more and more sluggish and crashed after about 1 min. Do yo think the mobo could be the problem?
Been there, done that. I'd have got the t-shirt, but I'm still too annoyed at it to laugh yet. Does anyone know what happens after verifying DMI pool data? i know it gets past that, because if I turn the cpu cashes off then on again it updates successfully, but still hangs. If I know what happend after that it would hepl me pin down which bits not working. (tho it looks like a new core 2 duo/mobo/ram for me :(
Having borrowed a friends pc, I was able to lift the BIOS backup off the HDD that I'd made before I flashed it (there hadnt been enough room on the floopy to back it up). Now back and running on the old bios. At least it works!
