- 9 May 2007
Hi all,
I have a shuttle SN25P and today it has started to play up abit. After a while, the machine just reboots itself, almost as though the reset button had been pressed. I wondered if this was a temperature issue due to the weather, so I backed the processor back to standard clocks (otperon 165) and the temps are all in control. The machine also froze on entry to windows once, so I opted to run memtest to see if the ram had gone bad, and at arround the 70% mark on the first pass the machine again "reset" itself.
I have also noticed that when it does get into windows, it takes a lot longer to load everything than it was doing even compared to this morning. I decided to run the Seagate hard drive diagnostic tool, and the drive failed the "DST-LONG" test.
What do people think is happening? I find it hard to beleive that its the shuttle system at fault (maybe though), and am just about to re run memtest hopefully with better results. Could a hard drive gone bad be causing the machine to power off due to a failsafe??
Any advise greatly recieved.
Cheers
Dan Chambers
Cheers
Dan Chambers
