System required for Mastercam
25 Oct 2013
Tipton
hi, been asked by a friend for a, in his words 'mega PC' to run mastercam comfortably.
this is his minimum req;
i7
32GB Ram
CPU Watercooled -corsair etc, nothing custom
3 x 30" monitors - 1080p
Nvidia Quadro (2GB min) to drive the Monitors, aware he might need 2 of them
240GB SSD
480/500GB SSD
any help guys
Go big or go home! :D
Hmm... struggling with monitors - OCUK only do 1 30" 1080p monitor and you're going to struggle getting Quadros with the right connections.
I've specced with 1600p Dells instead but I'm not sure the K2200 will have the grunt for 3 of them.
I think that the RAM's ECC (searched OCUK for a known set of Crucial ECC but then again the search feature is useless!)
My basket at Overclockers UK:
Total: £4,821.64
(includes shipping: £41.76)
TBH if this is being used on a professional level then you may well be better buying a prebuilt graphic workstation so you've got known compatibility, better stability and decent support.
