System service exception HELP !
98p
98p
6 Oct 2008
Somewhere in Australia
Hi I have had my pc for a while and never sorted the problems out, I managed about 6 months ago to get done what I had to and just put up with the problems. Now my pc wont startup beyond login screen before I get a SYSTEM_SERVICE_EXCEPTION BSOD. I have tried to look for help but I knew less than I thought, so if someone has some patience to try and help me it would be much appreciated.
I can sit in the bios without it crashing so I think it could be something to do with memory timings, or power voltage...?
Just any help would be appreciated.
Many thanks 98p
Is this a self build, a bundle or a complete PC purchase?
Is it overclocked?
What hardware is it, memory, cpu, motherboard, gfx?
probably memory but need more info.
A self buid
Gigabyte GeForce GTX 560Ti OC 1024MB GDDR5 PCI-Express Graphics Card Gigabyte GeForce GTX 560Ti OC 1024MB GDDR5 PCI-Express Graphics Card £197.99
(£164.99) £197.99
(£164.99)
Intel Core i5-2500 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail Intel Core i5-2500 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £169.99
(£141.66) £169.99
(£141.66)
MSI P67A-GD55 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) MSI P67A-GD55 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) £134.99
(£112.49) £134.99
(£112.49)
Coolermaster CM-690 II Lite Dominator Case - Black Coolermaster CM-690 II Lite Dominator Case - Black £61.26
(£51.05) £61.26
(£51.05)
OCZ Intel Extreme XMP 4GB (2x2GB) DDR3 12800C8 1600MHz Low Voltage Dual Channel Kit (OCZ3X1600LV4GK) OCZ Intel Extreme XMP 4GB (2x2GB) DDR3 12800C8 1600MHz Low Voltage Dual Channel Kit (OCZ3X1600LV4GK) £35.99
(£29.99) £35.99
(£29.99)
Needed it for 3d modelling in march havent used since i moved house and wont boot only BSOD. I think i might need to change the memory voltage or some memory settings but im unsure how to do so. I have a MSIclick bios which isnt standard for finding anything.
In the click bios OC menu, have you enabled the Intel XMP (extreme memory profile), if not, try that. Otherwise set dram timing to auto.
Fix CPU base frequency at 100MHz.
Just set the XMP to profile 1 and the others were at auto, should i have my RAM set to 1.65 volts? or will auto be okay?
BSOD on boot like normal
and keeps trying to switch itself back on...
try ram at 1.5V as this is recommended for sandybridge processors.
It could be a bios issue, I would try setting all to default. If that does not work, reset the CMOS.
