System Temp
17 Oct 2008
Was trying to reduce my fan speed/noise this morning when I notice my system temp was -65C how on earth is this possible??
Ras
Nope not on water, just standard case and mobo fans. The reading is from speedfan, I also recall seeing it before but cant remember what software. must have got rid of it when I upgraded to Win7
Ah speedfan does this with me as well, it's a known problem. It also gives false 100c readings for some things as well for some reason.
Try using Coretemp- that works fine for me. I used to use speedfan but found that 2 of my readings were erroneous, due to an issue with my motherboards compatibility.
HW monitor is cool coz its easy to read and tells you everything on one screen. Also has a x64 version.
One thing i will mention is that the zipped version gave me lower core temps (30c) than the installed version (45c).
