System Thread Exemption Not handled then memory Management Error in one aday
29 Aug 2014
To give you a bit of history i replaced every componant in the pc due to Bsod and it turned out to be the processor . Now i am getting Bsod again after doing another fresh install of windows on microsoft tech support advice . Im still getting one common Bsod and one i just got today but i think i fixed it . The first was system thread exemption not handled and the details are the minidump file and after actions i took are detailed below
https://1drv.ms/u/s!AsRWnERz9KUxga47ZLzW_zJQXyKRwA
The first link above is to the memory dump file for the system thread exemption not handled. I ran SFC scannow and it found corrupt files which were fixed then it found nothing .So i believe this problem to be fixed. Now once more im getting Memory dump errors.
The second one which ive had before about twice now in 2 days is Memory Management Error(link to minidump file above ). Question can this cause windows corruption and if so whats causing it? . I have four 8gb ram sticks but windows only reads 3 right now if thats a potential cause i cant fix it as i tried to change the configuration to optimal in accordance with the motherboard manual and got a black screen on boot so i changed it back to the last known working configuration which works as im typing to you on this pc .
I really just want a ******* working computer please help
