Hi all
After some advise please. I want to try to upgrade only my motherboard and CPU from an existing P4 rig to maybe a dual or quadcore (faster if can be done with existing components and not to expensive).
I want to spend around £200.
This is a second rig to an i7 and doesn't need to be overpowerful. Mainly for internet browsing, odd game and running music apps (Cubase and various plugings). Currently it runs too slow now for the calibre & amount of software/plugins being used at one time.
(Running XPx32 which again is fine for this rig, but may go W7 x32 in future)
I don't really want to have to upgrade my graphics card or memory unless very cheap. Idealy I only want to update motherboard, processor and memory if I really have to.
Thanks
Current Specs :
CASE :Lian-li PC7
PSU 400W
CPU Type Intel Pentium 4, 3400 MHz (17 x 200)
Motherboard Name MSI 865PE Neo2-PS (MS-6728 v2.0) (5 PCI, 1 AGP, 4 DDR DIMM, Audio)
Motherboard Chipset Intel Springdale i865PE
System Memory 4096 MB (PC3200 DDR SDRAM)
DIMM1: Corsair XMS CMX1024-3200C2 1 GB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz)
DIMM2: Corsair XMS CMX1024-3200C2 1 GB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz)
DIMM3: Corsair XMS CMX1024-3200C2 1 GB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz)
DIMM4: Corsair XMS CMX1024-3200C2 1 GB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz)
Video Adapter Radeon X1950 Pro Secondary (512 MB)
IC35L120 AVV207-1 SCSI Disk Device (120 GB, 7200 RPM, Ultra-ATA/100)
Disk Drive SAMSUNG SP2504C (250 GB, 7200 RPM, SATA-II)
Disk Drive ST320082 2A SCSI Disk Device (200 GB, 7200 RPM, Ultra-ATA/100)
Disk Drive WDC WD1500ADFD-00NLR1 (150 GB, 10000 RPM, SATA)
Optical Drive DVDRW PATA 20X20X12X
SMART Hard Disks Status
Thanks
Current Specs :
CASE :Lian-li PC7
PSU 400W
