System will only boot using onboard graphics
26 Jun 2010
Hi
I have just finished building a new rig with items recommended by the team here. I have the following new items
Intel i5 2500K LGA1155
ASUS P8Z68-V Pro Mobo
4gb of XMS3 Ram
OCZ Stealth Xtreme 11 600W PSU
I have added my graphics card Radeon 5770.
The problem i have is the system will only boot using the onboard graphics.
Any help would be great as it is driving me nuts!!
The fans spin but nothing gets through to the monitor and eventually the system turns itself off. Incidently when i boot the system i never get any beeps at all?
This was the PSU i was recommended so it should bge sufficient (at least i hope so or i've wasted a wack of money!)
Don't worry the PSU will be able to power it, unless it's a faulty PSU, but then I would imagine the whole system wouldn't boot rather than just when with the graphics card.
I have tried in both slots, ensuring power is connected but nothing. The system appears to boot up but nothing to the monitor
No, i use an old monitor when i build a new rig. I keep my old system as is so i can use it for problem solving such as this. The monitor i use when building is an old 14" CRT.
Have you changed the primary display adapter to PCIE in bios?
Does that motherboard have a built in speaker, or do you have one in your case? If not, that is why you will not get any bios beeps.
