- 22 Oct 2012
Hi all, my new build has started refusing to work using four DIMMs. After working perfectly for ~2 weeks *boom* come Friday she simply wouldn’t POST. The Debug LED initially showed a CPU error, after clearing CMOS this changed to a memory error. Removing any one or two sticks of RAM allows the system to post, boot into Windows and pass an hour of MemTest64
I’ve also tried:
I suspect that it’s the motherboard at this point (or I suppose the CPU) but would welcome any other theories or suggested tests. Full specs are in my sig but here’s an expanded list of the most relevant hardware:
• 4x8GB Patriot Viper Steel DDR4-4400 C19 (two dual channel sets) @ 3800 C16-16-16-16-32 1T / 1.35v / 1900 flck / geardown enabled
(tested at 2133 C20-21-21-21-42 1T / 1.35v / 1067 flck / gear down enabled & disabled)
• 5800X with PBO auto
(PBO off for testing)
• MSI MAG X-570 Tomahawk Wi-Fi
(7C84v14 BIOS – haven’t updated to beta BIOS as it’s beta, plus everything used to work perfectly on this one)
I’ve also tried:
- Downclocking the memory to base timings and frequency (133 C20-21-21-21-42 1T / 1.35v / 1067 flck / gear down enabled & disabled) to test; this has no effect
- Increasing NB (or on-die NB) voltage by 80mv; this also has no effect
- Swapping out the memory for four entirely new modules; this changed nothing
