Hang on, you were trying to use 4400mhz RAM downclocked significantly, then 4133, then 4000, the 4000 worked, clocked down to 3733.
Seems you are putting in RAM of a much higher frequency than the CPU can handle at stock speed, and/or that you intend to run the ram at, then the lowest frequency kit worked?
I am guessing here (stress that) but isnt that a factor here?
Maybe something in the bios was defaulting/clocking the ram at the original rated speed and it was soiling itself, or maybe the RAM itself doesnt like being run at such lower than rated speeds? Enough to work with 2 but not 4?
Just wierd how the RAM with the lowest stock fequency and that closely matches what you are actually running it at worked.
Zen 2/3 are notorious for being fussy with ram, although most people put lower stock ram and try and overclock it, you are doing the opposite, maybe it doesnt like it either way.
