Hey,
Just got my new BFG 7950GT 512MB PCI-E gfx card today and I am having problems running "some" games. Some of these games are dumping out with this BSOD... http://img242.imageshack.us/my.php?image=dsc00032mf5.jpg. I believe this is a driver error. The string error code is explained here at http://msdn2.microsoft.com/en-gb/library/ms793232.aspx and because the exception code parameter is 0xc0000005 this means that it is some sort of buffer overrun exception explained here: http://blogs.msdn.com/calvin_hsia/archive/2004/06/30/170344.aspx.
DXDiag
- DirectDraw test results: All tests were successful.
- Direct3D 9 test results: All tests were successful.
Games I have that work and are COMPLETELY stable and fast:
- Half-Life 2 (Default settings).
- World of Warcraft (Default settings).
- All DirectDraw games (i.e. Console emulators).
- All OpenGL games (i.e. Unreal Tournament '99, Half-Life, etc.).
Games I have that dump this BSOD:
- Warcraft 3 (lol ?!).
- Unreal Tournament 2004 X64 Version (D3D9 mode).
Things to note:
- The error codes and addresses reported are not random numbers and always refer to the same address.
- System is 100% stable (not 99.999999%, 100%!).
- Tried official 93.31 and beta 93.81 forceware to no avail.
- Used driver cleaner to remove ATI junk.
- I cannot be bothered to reinstall Windows X64.
Spec:
- Shuttle SN25PV2
-- 350W PSU (UNDERRATED. ~29A ON 12V!)
-- AMD X2 4600+
-- 2048MB OCZ DDR400
-- NForce4 Ultra controller
--- SATA2 NCQ Hard Drive
---- Windows XP X64 Edition (Legal)
--- SATA DVDRW
ALL STOCK SPEEDS NO O/C WHATSOEVER
Any suggestions?
DXDiag
Things to note:
Spec:
- Shuttle SN25PV2
-- AMD X2 4600+
--- SATA DVDRW
Any suggestions?
