22c lower at idle...impressive
- im going to stress it and see what happenscant hear it at allhey rjkoneill what's your impression of the sound of this beast with the 2 sharkoons on then?
Nice one rjkoneill! Great write up
Awesome looking cooler and great results too!
cheers - its a bit bulky but im happy with it
*ponders running a 4850 passively*
10c lower at full load compared to idle with stock! Very impressive.
Really want something like this for the GTX 280!
cool - i dont think it can run passivley
a review site i liked to earlier ran it passivley on a low end card and it overheated - lots
but the two sharkoons are whisper quiet anyway
but the T-Rad would jusssst about fit.
Time to check some fan dimensions
)i know - it will surprise me if they dont bring out a compatible version with nvidias next gen of cards - im guessing they will be a similar board layout to the current GTX 2** models.
Is it much heavier than the stock GTX blower?
Always good to see loads of nice pics btw (although my wallet would disagree)
That certainly would be nice but I wouldn't expect anything for this generation 260/280s due to the imminent 55mn die shrink?
Interesting review rjkoneill
I'm curious to know if this cooler is single slot? if running without any fans? From looking at your pictures the T-Rad2 does seem quite slim?
Thanks for that!its kind of 1 and a third of a slot
I'm looking at a cooler running GPU in a set-up with a 120mm fan blowing straight down onto the GPU, not sure how well the T-Rad2 will cool with from above cooling?have a huge amount of air blowing on it from a case fan
] so whilst the case is apart i may as well give a few setups a bash to see what works best
So will get to try it out on a 4870, will let you know how I get on....anythings got to be better than current operating temps and noiseQuick question, rjkoneill, I know you used it on a differernt card, but is it easy enough to get the stock cooler from the board, only asking as I dont have any of the TIM removal stuff.
