- 7 Mar 2005
- LU7
Hi. I've got a XHTML file with some CSS applied. I have a page with a table for a university module. The page also has a header, footer and menu. The header and footer are all set OK. But when the table is big enough that I have to scroll down to see it all the footer just goes weird and doesn't position itself where it should. I've tried a fair bit of fiddling and researching this kind of stuff so I'd appreciate it if anyone could give me a hand with this and tell me what I am doing wrong so I can fix it. I'm guessing that I didn't start with the right layout at the beginning?
This is for a university final year project btw so if you don't want to help because of that I understand.
You can find the html page and the css at http://www.marclister.com/ocuk/test/modules.html and http://www.marclister.com/ocuk/test/default.css.
The footer should be at the bottom of the page, as it is with others, but for some reason tables or the need to scroll down the page is ruining this.
OK
