I have Tado + Tado TRVs, it works great. I think when I got it Hive TRVs weren't a thing so I'm not sure how it compares.
They regularly go on offer so I believe I paid about £30 for each TRV rather than the current retail price.
Yup missed the black Friday deals and Tado clearance re their UK store due to Brexit. In reality, I'll just suck up the current prices I expect. I read about significant temperature adjustments required, even some instances where it's recommended to have a wireless thermostat in the rooms!
You'll generally figure out the temp and then "set and forget". Then if you ever need it hotter, on the Hive you just tap boost. Not sure if the Tado does it, but the Hive system also lets you configure TRVs to ask the boiler to come on, if you like.Yup missed the black Friday deals and Tado clearance re their UK store due to Brexit. In reality, I'll just suck up the current prices I expect. I read about significant temperature adjustments required, even some instances where it's recommended to have a wireless thermostat in the rooms!
Just to jump on this, did any of you find it difficult to change existing valves to TRVs at same time as this?
Any recommended TRVS to work with tado?
Thanks! I'll have to look into it when I move into the new house.I had to do this as none of my radiators had TRVs. I used these: https://www.screwfix.com/p/white-chrome-angled-trv-with-lockshield-15mm-x/31811. The Tado kit comes with a bunch of adapters for different TRVs, they fit on these ones without any adapter.
It's pretty simple to do, I think it took me a day to do it all but most of my radiators were a pain to get to.
Just buy a bunch of PTFE tape to properly seal the valve into the radiator.
Do the batteries on the valve actuators last long? Reason I'm interested is my mrs works from home so thinking of heating just the office extension (plus bathrooms) rather than the whole house during the daytime.
