Tag and rename help
8 Dec 2002
North Yorkshire
Ok to rename tracks which are named track 1 , etc I use some software called tag and rename really good program.
However it has trouble naming the 2nd cd of compilation albums , due to Amazon database thinking there all on one Cd i.E track 38 etc, when really "track 38" is track 18 say on cd 2.
Anyone have any experience using this software or have solution to the problem with using another program.
Any help would be great
thanks allot :)
It's been a while since i've used tag & rename but if i were to do it with id3-tagit (it's free, see the first google result) i'd highlight all the tracks from CD2 and click 'enumerate' which would number them from 1 to x. Is there a similar function in tag&rename?
I think you may have misunderstood me cd is already named 1-20 but the Amazon database think there called 21- 40 . so it renames cd 2 the same as cd 1 does that make sense. Just have a play with ID3
Thanks for the suggestion any other ideas
Media Monkey has a great function for this, mine just seemed to figure it out. Once its all tagged, indeed like 1-40 from amazon it has a 'create compilation' button which split them into 2/3 albums IE
Clubland 10 CD1
Clubland 10 CD2
As different albums, with the right tracks.
Clubland 10 CD1
Clubland 10 CD2
Maybe I was been thick but I couldn't get media monkey to find any albums :confused:
Either way tag and rename sorted job out :D
