Tamron 24-70
I was looking at the lens as a photographer point of view not videographer.
So does anyone know if anyone has shot a wedding with just this or with another for the day?
A 24-70 is a very common lens for weddings, used by many pros combined with a 70-200m f/2.8. If you are on crop then a 17-55mm f/2.8 might be better or add a wider lenses.
I second shot a wedding with a 24-70 and 70-200 as my primary lenses on a crop body. 70-200 is useful for some reportage style shots in the evening, to capture details but can also be a critical tool if you are in a church that requires the photographer to be at the back of the church. I have also been the primary photographer at a civil wedding and used a 35mm f/1.8DX, 50mm 1.8DX, 70-200mm f/2.8 and a 16-85mm f3.5-5.6VR for groups. The primes give great shots, help when indoors or when you want a shallower DoF.
However, I actually found my 16-85mm f3.5-5.6 to give fantastic results and a lot of keepers, faster AF than the primes, shooting at f/8 captures a lot of the details and much less likely to give focus errors. when you shoot with a shallow Dof you have a very high chance of getting a focus error because someone moves their head that fraction of an inch and bamb, ruined photo. Common problem with beginners is to assume you should always shoot razor thin DoF, you will end up with a load of photos where either the bride or groom is in focus, but not both, or only 1 eye and not the other - looks very amateurish (at the sme time you don't want distracting background so if you shoot with a narrower aperture then be sure to keep an eye on what is behind the subject, moving a few steps to the side can make all the difference in change a fire exit sign to be a flower arrangement).
I wouldn't shoot solely primes on your first wedding unless A) you were very confident in using the primes, B) you can rapidly swap lenses without looking, having lenses strapped to your belt.
Nothing worse than someone stuck at the same focal length and not controlling perspective properly by changing lenses or simply using a zoom lens (just as bad if not worse than not moving your feet).
Cheers D.P
5D MK3 - I've posted on TP also, how does the MK3 compare to the D3s for low light work?
Atm my shopping list is!
5D MK3
Battery Grip + 2 Canon batteries £50 a pop :o
Tamron 24-70
Tamron 70-200
Was going to get a 35mm Sigma but feel its covered with the 24-70 but maybe 16-35mm?/2.8 so i can cover groups etc?
Firstly I would ditch the Tamron 70-200 (didn't even know they made one). If your going for a 70-200 then the Canon L MKII is the best. I think Sigma offer a good substitute.
Personally I would ditch the 70-200 altogether and get a Sigma 85 1.4.
http://rising.blackstar.com/if-your-pictures-arent-good-enough-youre-not-close-enough.html
Apart from group shot's of 'everyone', I use an 85 @@1.4 given enough room. Else 35mm @F5.6 is plenty wide enough imo.
The difference in ISO between the D3s and 5D3 doesn't outweigh the 5D's resolution advantage imo. That sort of question is easily answered in DXO. Basically the D3s has approx. 0.3 stops advantage.
FYI, The D3s is still the champion of low light work and is clearly ahead of all other cameras. This difference was pretty huge in the days of the Canon 5DMKII etc. but the 5dmkIII is improved so the difference is nice for anyone who works in low light consistently but is not such a game changer as it used to be (D3s attracted quite a few Canon pros to swap system, especially togs doing indoors sports who are always struggling to capture every single photon).
Interestingly the new D4 is marginally worse at high ISO.
5dMKIII is an excellent wedding camera, definitely recommend it over the older 5dMKII due to the better AF which can be important in weddings compared with landscape work where the 5dMKII is just as a good a camera.
The Tamron 70-200 is very good though. I agree that an 85mm prime is likely to be better in many situations but as has been mentioned, if you are stuck at the back of the church which is very common then 85mm wont cut it. At my sisters wedding the pro-tog used a step ladder and a 300mm f/4.0 form the back of the church, he had no choice.
The D4 is marginally worse at high ISO but you still get a lot more room to play with. The D3s makes a lot more sacrifices than just resolution for the sake of its ISO performance - its colour depth and dynamic range are on significantly behind the other sensors in the Nikon line.
^^^ I completely agree but it is interesting that the noise performance is marginally worse rather than marginally better.
