then tbh you're asking for an expensive bill. Also edit you post for you, think that should be what it says
Yeah well.
I will check them some time today then
With the level of neglect and negligence of you owning a car, with no regard for basic maintenance I hope your car does go bang, then you might learn.
I bet you most people will not check there engine oil or anything else.
 ) just trying to help you out & save you hassle in the long term.
) just trying to help you out & save you hassle in the long term.I bet you most people will not check there engine oil or anything else.
Your probably right. It does not mean its right though....
Were not having a pop (well, I'm not anyway!) just trying to help you out & save you hassle in the long term.
