- 24 Dec 2007
Hi,
I'm wondering if any of you know if the Team Dark Pro memory is compatible with the Be Quiet Dark Rock Pro 4 air cooler? I know the Dominator platinum ram doesn't fit but as far as I can tell this memory is about 1cm shorter.
Does anyone know if theres enough clearence for it? I'd be using the X470 Crosshair VII motherboard.
Thanks
Thanks
