Team Group Dark Pro "8 Pack Edition" 16GB (2x8GB) DDR4 PC4-25600C14 3200MHz
Caporegime
4 Jan 2011
Hi @8 Pack
So I bought these with a 2700X/Asus CHVII (andthe remainder of a build) from yourselves in September.
Constantly had crashing issues and assumed it was GPU but I’ve since switched and still gettingthe same crashes from games/bsod.
I’ve ran memtest and got errors at the advertisedspeed/timings (also increased voltage to 1.4 but still the same)
Any ideas? Was contemplating getting a second kit to increase to 32GB in black Friday but bitpointless when I can’t even get 16GB working
Did you set the timings manually or through xmp?
Is the ram running in dual channel in the correct slots? (Check mobo manual to be on safe side) I've got to put mine in slot a2/b2 for dual channel to operate correctly.
Could be faulty ram I guess, as I've got mine running at 3466 cl14 with xmp settings for 3200 and also with manual timing using dram calc settings.
Hi I have a ryzen system so I think asus called it docp and it is enabled. I also do have it in slot 2 and 4.
My system is as follows:
  • Motherboard:asus Crosshair x370 (latest 6302 bios)
  • CPU:1800x @ Stock
  • Memory:Team Group Dark Pro Edition 16GB (2X8GB) DDR4 PC4-25600C14 3200MHZ
  • Graphics card(s): 1080ti
  • PSU:corsair ax 760
Try running the ram at 2133 or whatever the board defaults to if you reset everything to factory defaults, run memtest again then if still getting errors try one stick. After that might be RMA time...
Did you try Ryzen DRAM calculator by the way?
