Tech question re watching a downloaded file on tv
19 Mar 2011
Ok i have a file if am honest its a movie trailer, and i am struggling to figure out a dilema i have about trying to watch it.
the file is moviename.trailer.2016.1080p.bluray.h264.aac-rarbg.mp4
i have an external seagate 1tb drive and i also have a western digital 2tb wireless passport pro drive.
i use the seagate via a usb direct into the tv the wd is used wireless
the file is on both devices but only the seagate drive will play it without issue, if i try to view it from the wd the tv pops up with unable to play file.
so my question is why will the seagate play it and the wd will not?
thanks
You need to swap the drives to see if the WD will play the file via USB. It's either the way the TV is reading the file over wireless, or it's the way the WD is presenting the file to the TV. Does the Passport do anything other that serve the file? Is it running some kind of media server that the TV is picking up wirelessly? Try renaming the file to end in .MKV and see what happens.
thanks for the reply, unfortunatly i do not have a standard size usb to usb cable for the wd drive :( the drive itself has 2 server settings in its prefs they are plex and twonky i am unsing the twonky as i find this easier for my novice skills. the passport does nothing except present the file to the tv. will try the renaming bit and see what happens
Try Plex and/or renaming the file to MKV. I'm suspecting that Twonky is doing something weird in the way it presents the file (or not changing it to something more compatible) and your TV isn't trying to play it once it sees that.
buddy if i was close to you now i'd buy you a beer, i changed the extension to mkv and it played first time via the passport wireless :) but the strange thing is i do have other mp4 files on the same drive that play without issue.
cheers
cheers
I would guess your file has some kind of non-standard encoding that the TV is choking on, but within a MKV, it's not doing the same checks and the difference isn't too far from what your TV can support. I reckon your Seagate is just acting as a storage drive, and your passport is acting as a Twonky DNLA server, and the difference is where Twonky is serving the file to the TV.
There are a lot of systems out there that are really fussy about different types of files (even variations on the encoding within the same file format), and won't even try to play things. As soon as you put it in a MKV (which is just a container that can have loads of different things inside, often MP4), then the TV actually attempts to play, and unless the file is too weird, you often find things work.
If quick fixes like renaming the extension don't work, then it's quicker just to run a file though an encoder to get it back to some kind of standard format that your TV can deal with.
