I find that whitening toothpaste has no real effect, if you want whiter teeth, either get it done by your dentist or use whitening strips.
Porcelain veneers are the best way to get them done. [...]
I only use it if ive missed a lot of brushing/feel my teeth arnt looking that white) Google it for more info its amazing!
I drink a lot of coffee and though my teeth aren't bad, they're not as white as they used to be. My other half said I should get some of this, so I went looking for it. It comes in two versions - normal and extra (for smokers, coffee people), so I got the stronger one. Does it work? Does it ********and also Blanx is a new product I see out there now
. Complete waste of money in my opinion. I've got through virtually an entire tube now, and I can't see any difference at all.It worked for my sister - her dentist even commented. Not at all for me.I drink a lot of coffee and though my teeth aren't bad, they're not as white as they used to be. My other half said I should get some of this, so I went looking for it. It comes in two versions - normal and extra (for smokers, coffee people), so I got the stronger one. Does it work? Does it ********. Complete waste of money in my opinion. I've got through virtually an entire tube now, and I can't see any difference at all.
Where do you guys get your crest white strips from and how much do they usually cost?
Holy 8 year Necro !!
