Well, we have acid related tooth decay, varying difference thickness of enamel, the predisposition to bruxism (tooth grinding) etc.
<-- seeI think the thought of a needle in your mouth is the scary part , its just a scratch like any other needle. find an nhs dentish and it isn't expensive
http://www.nhs.uk/NHSEngland/AboutNHSservices/dentists/Pages/nhs-dental-charges.aspx
picked and polished my teeth, a few months down the road started getting extreme sensitivity to hot and cold down the left side of my mouth. Hoping it just goes cause the bills are extortionate!
It's in situations like this I turn to the question...
What Would Brian Boitano Do?
!You implied that by avoiding sugar you can avoid tooth decay.None of which are tooth decay.
One is erosion of enamel.
One is attrition.
One is abrasion.
Decay is specific, it is called tooth decay, you need four things, a tooth, bacteria, time and sugar.
Thats tooth decay, the other are various different things which can damage teeth.
In rare cases people can have dentinogenesis imperfecta, and amelogenesis imperfecta, or malformation of the tooth follicle, this can lead to decay affecting teeth at a faster rate, and the other things you mentioned leading to damage at a faster rate.
The original statement remains accuarte, tooth decay is caused by sugar feeding bacteria, which produce acid to damage the tooth. Without sugar you will NOT have tooth decay. Acid damage, erosion, attrition, abrasion are all different ways to damage teeth, stop calling them tooth decay, they are not.
I had a lot of unnecessary work (fillings with no sign of decay) done by unscrupulous NHS dentist when I was younger.
