I know I need to do some cable management, but, meh!!! What I have done is lifted the case from the floor onto a small desk to give some more airflow around it.
I wanted to make sure my temps were ok.
All running stock- Idle Temps
Antec 900-2 Case
Gainward 4870 x 2 GS - 47 Deg C
P6T Deluxe Board running i7 920 2.66 - All cores between 27 and 30 Deg C
Noctua NH-U12P cooler, front fan blows, rear fan sucks.
FWIW 3 fans on front of case are on low, the ones on the back are set medium and the one on top set low.
Antec 900-2 Case
so i use that
