- 10 Apr 2014
- Hampshire
What are the sensor wires called that go with the aquacomputer temp sensor display ?
Is it the 2 wire temperature sensor extension leads you're thinking of?
You're looking for a 10K temperature sensor. Any will do as they all work on the same principle.
