Probably been well documented somewhere before but I'm not having much luck finding anything solid.
Is this any problem ? My currently installed E6600 seems to be running about 4 sometimes 5 degrees differnent between Core 0 and Core 1.
Now I'm sure the IHS is seated correctly and the same CPU read much closer temps when I used it in a DS3, wondered if thats anything to do with it.
Should I just forget about it and stop being so paranoid, or try and remedy the problem as its sure to end in TOTAL disaster ?
Thanks
![Stick Out Tongue :p :p](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
Thanks
